Discussion topic: Sky Q issues
This message was authored by: Hammerette08
Message posted on 16 Jun 2025 10:17 PM
Sky Q issues
We are having intermittent problems with our tv. Sometimes screen goes blank (completely black) we are often told to check the source, sometimes pictured is distorted before screen goes blank and I have discovered tonight that our satellite signal is showing as "Locked". Is that correct?
Find out more
Message posted on 16 Jun 2025 10:30 PM
Re: Sky Q issues
Yes @Hammerette08
Locked is correct.
As in locked on target.
Have you checked your HDMI lead is correctly fitted at both ends.
Also try another lead if possible.
