Discussion topic: Sky Q infrared remote tv pairing
This message was authored by: Sc0t
I have a Sky Q infrared remote, I recently bought a new TV, it wouldn't pair as the old one did (TCL32) I'm going to return and buy a TV that will pair, can someone recommend a budget TV that the remote will pair with?
Re: Sky Q infrared remote tv pairing
I wouldn't go to the hassle of taking a TV back just due to using two remotes.
what TV is it?
Avatar for Sc0t
Thanks @Chodley I get what you mean but there's more than just me using the TV and it is quite frustrating after being used to only 1 remote, the Sky one, for years! I've read loads of posts on here before submitting mine, advising on different manufacturers from JVC to Vestel and tried literally hundreds of codes all without success.
model is: TCL32SF540K with Amazon fire built in.
wrong information given  I need to read the post properly
