2
This discussion topic has been answered Discussion topic: Sky Q hard drive errors
This message was authored by: JayneF
Sky Q hard drive fails - reset works for a couple of hours then requires another reset, will Sky provide a new box ?
Re: Sky Q hard drive errors
@JayneF
Try following this link. It should lead to a replacement box if needed https://www.sky.com/help/articles/sky-q-hard-drive-errors
If you do need a new box remember to remove the viewing card from the faulty box and accept any new power cable DPD deliver with the replacement box.
@JayneF
Avatar for JayneF
Level 0 icon
Yep done all this & very annoying when the Check your Sky Box says - everything is working correctly- shame it can't hear me shout at it 😆
