This discussion topic has been answered Discussion topic: Sky Q hard drive errors
Message posted on 23 Jul 2025 05:56 PM
Sky Q hard drive fails - reset works for a couple of hours then requires another reset, will Sky provide a new box ?
Message posted on 23 Jul 2025 05:59 PM
Try following this link. It should lead to a replacement box if needed https://www.sky.com/help/articles/sky-q-hard-drive-errors
If you do need a new box remember to remove the viewing card from the faulty box and accept any new power cable DPD deliver with the replacement box.
Message posted on 23 Jul 2025 06:04 PM
Re: Sky Q hard drive errors
Yep done all this & very annoying when the Check your Sky Box says - everything is working correctly- shame it can't hear me shout at it 😆
