Discussion topic: Sky Q had wrong BB
This message was authored by: Hibby1875
Sky Q had wrong BB
Sky Q told me i wasnt connected internet. Checked this out through settings. It showed it couldnt connect to Sky Ff5B7. Well i wasnt surprised. I dont have a Sky router - I use Virgin.   Had to figure it out how to reset to Virgin. Never seen this one before.   Any ideas why it happened?
Re: Sky Q had wrong BB
Hi @Hibby1875
You were probably looking at the SSID of the Sky Q mesh which is broadcast by the Q boxes.  This is normally shown in the Q box network details.
If you were trying to connect by WPS then it may have been a neighbours Sky Network.
You couldn't mistakingly connect to that unless the neighbours router WPS button was pressed within two minutes of you trying to connect.
As you now know I suspect,   you have to input your Virgin SSID and password for its 2.4Ghz band following a Network reset on the Q box to connect to your router.
You can only use WPS when on Sky Broadband.
