Discussion topic: There is no signal since yesterday evening
Message posted on 29 Jul 2024 08:16 AM
There is no signal.My sky is not working since yesterday evening
Message posted on 29 Jul 2024 08:19 AM
Re: There is no signal since yesterday evening
@Tauyanyahwe85 wrote:
There is no signal.
@Tauyanyahwe85
A message displaying ”no signal” tends to be from your TV.
Any message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
