2
This discussion topic has been answered Discussion topic: Sky Q guide.
This message was authored by: Fidel+59
Sky Q guide.
What's happened to the Sky Q guide?
Have I pressed something? And why is some highlighted white and some black?
Tried to post picture but not allowing 🤔
N Jenkins
Re: Sky Q guide.
@Fidel+59
I suspect you may have inadvertently switched to the High Contrast accessibility mode.
To toggle this:
Press Home on your Sky Q remote and select Settings.
Select Accessibility, then High contrast and change the setting from On to Off.
Press Dismiss to return to live TV.
https://www.sky.com/help/articles/using-the-accessibility-settings-on-your-sky-q-box
Re: Sky Q guide.
@Fidel+59
To toggle this:
Avatar for Fidel+59
Level 4 icon
Re: Sky Q guide.
Yes that seems to have sorted it. And the different colours was because I had notification for subtitles.
Thank you. ✌️
N Jenkins
