Discussion topic: Sky Q freezing
This message was authored by: SPB11
Sky Q freezing
At least once a day my Sky Q is freezing and I have to unplug to restart. The picture is either stuck on one channel or will not even have a picture. This is happening daily, sometimes more than once and the only way to resolve it is to unplug. I am on Sky broadband and have checked that, I have checked all the Sky Q/TV cables
Re: Sky Q freezing
Have you tried the service checker in the MySky app or online and does it indicate any known hardware issues?
If it does, it should guide you to next steps. If it doesn't, sign in online here and work through the flow: https://www.sky.com/help/sky-tv/sky-tv-q/fixing-sky-q/fixing-q-equipment
Your aim (should none of the steps help), is to get directed to book an engineer or arrange a box swap if needed.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
