Discussion topic: Sky Q freezing
This message was authored by: DaveC250
Sky Q freezing
Recordings are freezing and losing sound. Especially in UHD.
When fast forwarding it keeps jumping back. Also very laggy. I have disconnected the power and restarted the box but this didn't fix it.
This message was authored by: bemak187
Re: Sky Q freezing
@DaveC250Is watching live TV ok?
Avatar for DaveC250
Re: Sky Q freezing
Yes live tv is ok.
Re: Sky Q freezing
@DaveC250 To be honest sounds like the hard drive in box is on the way out.  Do you have a lot of stuff recorded/saved?
Avatar for DaveC250
Re: Sky Q freezing
Yes quite a lot. I called sky yesterday and they went through some sort of reset with me. It was ok for a little while.
but playing up again now.
