2
This discussion topic has been answered Discussion topic: Sky Q freezes
This message was authored by: Skyboxfrezzes
Sky Q freezes
Pause a tv channel, for example 5 minutes.
then fast forward to catch up to real time, the fast forward doesn't stop at real time, just keeps counting up into unseen tv.
press exit on remote and tv is frozen and have to reboot Q box.
had a problem with this and a hard drive issue, so have replaced Q box and hard drive seems ok but still freezing issue.
Re: Sky Q freezes
Hi @Skyboxfrezzes
First thing to do is a Software Update to make sure the box is on the latest Software.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
Any Q box (including minis) may require a manual software update at times.
For example a replacement Q box or mini or any box that is powered off when an update is released.
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
All Q boxes and minis should be on the same software version.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software
Then carry out a Reset Settings in the Q box hidden menu.
Re: Sky Q freezes
Hi @Skyboxfrezzes
This message was authored by: Turbo7
Re: Sky Q freezes
Picture keeps freezing & cannot get on demand and catch up TV
