Discussion topic: Sky Q error message from
Message posted on 11 Sep 2023 02:04 PM
Good afternoon, I get error messages when I try and record a show, watch a previously recorded show, also with catch up shows. I get a variety of messages from cannot record because of techincal issue to show is not avalaibe any more.
switicjing the box off then on again resolves the isssue temporarily, but sooner enough the error messages return. What can I do?
Message posted on 11 Sep 2023 02:10 PM
Re: Sky Q error message from
Hi @HenryvdW
