10
This discussion topic has been answered Discussion topic: Sky Q daily updates?
This message was authored by: Peemac
Over the last week, every morning, the Sky Q is updating - is this normal?
This message was authored by: xenon81 Answer
Re: Sky Q daily updates?
That sounds more like a fault. The reboot will happen at 05:45 and will only take a moment or two, nothing should still be happening at 09:00.
No. What is happening, is there a message on screen?
@Peemac
New Q firmware is released every few months, and once applied shouldn't create any notifications.  Getting something every morning would be an error, and typically indicates that an update has misfired.
Is it possible that what you are seeing is actually a smart television operating system update message?
Avatar for Peemac
Thanks for responding  but no, it's not the TV.
The Sky Q box has been actively doing something, every morning and cannot be accessed or TV watched until completed.
Avatar for Peemac
Something slong the lines of "Sky is updating and will load in a few minutes"
This message was authored by: Invisiblename
Is this in the early hours of the morning?  The box automatically re-starts every day & it could be this that you are seeing
I am just another Sky customer!
Avatar for Peemac
@Invisiblename  - thanks for your input!  It seems to happen every morning but the box is whirring really loudly for a very long time. I was used to update happening in the early hours but, lately, it's anytime up until 09:00
Avatar for Peemac
@xenon81  - thanks!  My thoughts exactly...
This message was authored by: Lunar2
Should I contact sky
About what????
