Discussion topic: Sky Q connectivity
Message posted on 08 Mar 2023 09:33 PM
Sky Q connectivity
Message posted on 08 Mar 2023 09:39 PM - last edited: 08 Mar 2023 09:40 PM
Re: Sky Q connectivity
I've had mine for 3 years now and do a full reboot around every 3 months to clear out any cobwebs.
I'd suggest fully rebooting both the router and the Sky Q main box & minis.
Unplug all of them, same time, from the wall for at least 30 seconds.
Plug back in the router only, get it up and running, and run a speed test on your mobile. Now plug back in the Sky Q box, go to settings, and reset the network settings section. Then scan for your router, add in your password, and hopefully, you're back up and running. Now turn on the minis and re-pair to the main Q box.
EDIT: How full is your HDD? Obviously, the fuller HDDs will impact the performance of the boxes.
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Message posted on 08 Mar 2023 09:45 PM
@Jeffs77 wrote:
How long does a sky Q box last......mines starting to get slower and keep having to reconnect the mini boxes event though no issues with WiFi?
@Jeffs77 had my current bos since October 2017 and no problems at all with nothing wrong with the previous box I had as well only swapped as I was trialling the V2 box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
