Discussion topic: Sky Q boxes need unplugging every time!
This message was authored by: spalden
I have a sky Q box and 2 sky minis that I've been running fine for a couple of years without too many problems.
But now, all 3 of my boxes have stopped turning on initially with the remote, they need to be switched off at the plug and reconnected every time I want to watch TV.
If I switch off the main Sky Q box at the plug, then do the same with the mini, it will go through the whole reconnecting process  and when that's done, it's absolutely fine. I can switch it off with the remote and switch it straight back on again but if it's left off for more than a couple of hours, I come back to it and it has to be unplugged and reconnected again.
If I just switch off the mini at the plug, I can then turn it on with the remote but it will fail to connect unless I also go and unplug the main box as well. It's a right pain in the backside, particularly as one of my sky mini boxes is up in the bloody loft!
Very strange that all 3 boxes have developed exactly the same fault at exactly the same time 🤔
Any suggestions please?
This message was authored by: Mr+Flibbles+86
Re: Sky Q boxes need unplugging every time!
Hi there @spalden , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
This message was authored by: Lisa-P1987
Thanks for chatting to us @spalden . Unfortunately, there was no further response on the chat in 48 hours, we are still waiting to help you. If you need our support let us know and we can re-escalate to our chat team. Your chat has been closed now. Thanks
Lisa - Sky Tech Team Expert
This message was authored by: RDC87
I've had this issue, as have many others for months.  I've changed box and change leads and hdmi socket. Clearly a Q box issue which is ridiculous given how much we pay😡😡😡
Box isn't rebooting properly after its nightly power cycle. When mine did this I had to get a new box but try the usual reset things first.
https://www.sky.com/help/articles/sky-box-problems
This message was authored by: DrewHewitt
I'm having a similar issue, is there a way to fix it?
Did you read the post above yours?
