Discussion topic: Sky Q box
This message was authored by: Jodi-
Sky Q box
Sky Q box no longer turns my tv on
Re: Sky Q box
Hi @Jodi-   If nothing has changed, try power rebooting both the TV and Sky Q box. Review the HDMI control on both.
Avatar for Jodi-
Re: Sky Q box
Thanks for your help I've tried turning everything off and back on that didn't work, I took the tv upstairs to use on my mini box it worked fine I brought it back downstairs to the main box and now it won't work
Re: Sky Q box
Hi @Jodi-   Did you review your HDMI control? Home -> Settings-> Setup -> Audio visual -> HDMI control -> On. Checked the cable is seated correctly, used the HDMI cable from upstairs.
Avatar for Jodi-
Re: Sky Q box
Hi, I tried using the HDMI from upstairs I still can't get the tv on as I've not got a remote so I'm unable to see anything on the screen
Re: Sky Q box
hi @Jodi-
If the TV is not switching on & you do not have the TV remote try looking at the back of the TV for the power button and 'source' button - I know some TVs do not have them but most do, although they can be difficult to find
Avatar for Jodi-
Re: Sky Q box
Thanks I'll try having a look
