Discussion topic: Sky Q box
Message posted on 26 Dec 2025 08:43 AM
Sky Q box
My sky cue box is not working
Message posted on 26 Dec 2025 10:01 AM
Re: Sky Q box
Some more details other than 'not working' may help us to help you.
Message posted on 26 Dec 2025 10:39 AM
Re: Sky Q box
My sky q isnt working either. All the status are ticked but it is saying there is a technical fault and waiting for tv schedule.
Message posted on 26 Dec 2025 10:40 AM
Re: Sky Q box
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Message posted on 26 Dec 2025 10:58 AM
Re: Sky Q box
Thank you. It has reset it but now the remote won't move anything on the screen!! So I can't get it off the blue screen with the info about accessibility on Sky q click settings or skip and set up later!!
Message posted on 26 Dec 2025 11:00 AM
Re: Sky Q box
Upstairs boxes are now fine! We are going to turn on and off again and see what happens......
Message posted on 26 Dec 2025 11:02 AM
Re: Sky Q box
Sky have suggested the following...
- Unpair their Sky Q remote from the box by holding 4&6
- Wait for the remote to flash
- Then dismiss the information screen "Skip & set up later"
- Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Message posted on 26 Dec 2025 11:06 AM
Re: Sky Q box
Amazing! Thank you! All sorted 😄
