Discussion topic: Sky Q box
This message was authored by: Dissatisfied4
Sky Q box
Everyday I turn on Sky Q box to watch tv it says on tv screen no signal...and have to take out electric plug socket and plug back in again then it works..
so frustrating!!!
Re: Sky Q box
@Dissatisfied4
No signal and no satellite signal issues are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re actually seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
