Discussion topic: PTC Punjabi Channel sounds strange
This message was authored by: Jay8899
Only PTC Punjabi is effected, every other channel is fine. Tv is fine, restarted box but still the same.
it's very screechy and distorted - anyone else have this issue?
Re: PTC Punjabi Channel sounds strange
hi @Jay8899
I have just listened for a short while & there does seem ro be an issue .
If the problem persists tomorrow then probably woth emailing Viewer Relations : viewerR@Sky.uk who should be able to  contact the Channel
Avatar for Jay8899
Thank you, I'll email them.
it's been like this for over a week
This message was authored by: Shopkeeper1970
Hi, did you ever get a resolution to this. My mums is having the exact same issue. I've tried everything to fix it for her but to no avail sadly
hi @Shopkeeper1970
Like with the original report, I have just tried listening & whilst I think the sound may possibly be able to be understood (I am afraid I do not know the language in use) it does again seeem distorted.
The advice is  as above to email  Viewer Relations : viewerR@Sky.uk
Thank you very much for replying.
If you are hearing the same issue with the audio I can most likely rule out it being a problem at my end with hardware or weak signal etc. All other channels are fine in every way.
Thank you for the email contact. My mother is no longer a Sky customer so I'm not sure how much they will be willing to help but still worth a try.
Thanks again
Avatar for Jay8899
I never received a response from sky, they don't seem to care
