Discussion topic: Sky Q box
Message posted on 30 Apr 2024 12:03 PM
Sky Q box
Hi we have been having trouble for the past 2 weeks now with our TV going blank every time we want to watch Sky. Our TV still works with our main channels , but stops working when we use the Sky remote. What do i do?
Message posted on 30 Apr 2024 12:05 PM
Re: Sky Q box
Hi @FinlayJ2014
