Discussion topic: Sky Q box
This message was authored by: daveham
Sky Q box
My Sky Q main box is not working but the 2 mini ones are working fine. I don't even get the hello on the TV. It was fine yesterday but switched on today and nothing, anyone know what this could be. I have already reset everything and also changed HDMI leads, so it's a bit weird. Thanks in advance
This message was authored by: Invisiblename
Re: Sky Q box
Are you sure you've got your tv set to the correct HDMI input for your Sky Q?
I am just another Sky customer!
Re: Sky Q box
@daveham when you switch the box on does the green light on the main Q box come on ?
If it does you could try pressing the following sequence of buttons the home button followed by 1080 and then the home button again
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
