Discussion topic: Sky Q box
This message was authored by: Hunty+Bunty
Sky Q box
My sky q box has frozen and I can't unlock it...
Re: Sky Q box
Hi @Hunty+Bunty
Try rebooting your Q box.
If the Remote did not bring the Q box and you had to use the standby button on the Q box,
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for Hunty+Bunty
Re: Sky Q box
Thank you for the prompt response...I will give this a try...
