Discussion topic: Sky Q box
Message posted on 01 Apr 2023 08:52 PM
Sky Q box
Can I wall mount my sky Q box?
Message posted on 01 Apr 2023 08:57 PM
Re: Sky Q box
Message posted on 01 Apr 2023 09:13 PM
Re: Sky Q box
Yes u can buy wall mounts for it on ebay and the mini boxes I had one for my main box but it's at your discretion I wouldn't mount behind the TV or anything like that I only had it mounted under my TV as I didn't have room for a shelf or cabinet or anything so I just mounted it under my TV
Message posted on 01 Apr 2023 09:24 PM
Re: Sky Q box
You can buy many wonderful things on eBay @Matto+E
I Would still point out the following
My Sky Q box is warm
It’s completely normal for your Sky Q boxes to be warm as they’re built with “breathable plastic” that naturally releases heat through the top of the boxes.
