Discussion topic: Sky Q box will not update
Message posted on 03 Aug 2024 10:36 AM
Been having issues for a while and getting sick of it, box downloads the update and says will be loaded after being placed on standby. however it never updates.
Tried rebooting it and nothing works, any ideas, is 6 years old so possibly on its way out?
Message posted on 03 Aug 2024 10:41 AM
Re: Sky Q box will not update
Hi @Smudger771
what version are you on?
Bear in mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
Message posted on 03 Aug 2024 10:44 AM
Thanks for that, appears I am on the current version so box must be on the way out
Message posted on 03 Aug 2024 10:48 AM
Hi @Smudger771
Try a Reset Settings in the main Q box hidden menu.
