7
This discussion topic has been answered Discussion topic: Sky Q box will not connect to Sky broadband
This message was authored by: Kerry7307
Last weekend the Internet went down, since then I have tried everything to connect Sky Q Box back to Sky Broadband. Nothing has worked. I've reset, rebooted, you name it! Had enough now. Any help would be appreciated, thank you
Re: Sky Q box will not connect to Sky broadband
@Kerry7307 wrote:
@oldfella yes the wps light flashes orange on both the router and sky q box. Yes I did this within 2 minutes
If you reset the Sky Router first with the reset button then I cannot see anything else you can do @Kerry7307
Apart from contacting Sky for a Q WiFi booster to position midway between the Q box and the router.
I suppose you could first try a Reset Settings on the Q box first and then try the complete procedure again (reset router etc etc)
Hi @Kerry7307
Sky Q router WPS button.
Avatar for Kerry7307
Thank you, I've just tried all of this but it still has not connected. Anymore options?
What happens when you carry out the Network reset @Kerry7307
Does the WPS light flash on the Q box?
Did you press the WPS button on the router within two minutes?
What colour was the Router WPS button flashing?
@oldfella thank you for all your help, after trying this for the 2nd time it's finally connected. Very much appreciated 🙂
Hi @Kerry7307
Did you have to try the Reset Settings or just repeat the first procedure?
