Discussion topic: Sky Q box wifi
Message posted on 31 Mar 2024 10:37 PM
Sky Q box wifi
Why does my phone (or other device) right next to my sky box get a WiFi download speed of 70+Mbps...but checking speed via Netflix app on Sky (as suggested) says only 8 Mbps? Seems like WiFi speed is absolutely fine in house but not to sky boxes. Can't use Ethernet as too far from router. Seen people suggesting power line things - what are these, might they help and what do I do them with them? I've been a loyal sky customer for over 20 years but I'm sick of it not working anymore - channel 4 app unwatchable as buffering so much and downloads take hours. Never used to have these problems even though my WiFi is much much faster now.
Message posted on 01 Apr 2024 10:11 AM - last edited: 01 Apr 2024 10:12 AM
Re: Sky Q box wifi
hi @SOOKIE+D
Who is your internet provider - if it is not SKY (which I am guessing it isn't) then your SKY Q box will only connect to your router using the 2.4GHz wifi band, wheras your other devices may be using the the higher speed 5GHz band - thus there may be a problem with your 2.4GHz signal where your box is.
Powerline adapters are devices which let you use your mains wiring to be used as ethernet connections - you use a short ethernet connection to a powerline adapter at each end and the mains cable in between acts like you had an ethernet cable running the whole distance
Message posted on 01 Apr 2024 03:34 PM
Re: Sky Q box wifi
Hi, thanks for your reply. Yes, it's BT broadband now. Is the issue with the router something I can do anything about? (or am I better just cutting my losses and investing in some power line connectors)
