Discussion topic: Sky Q box turns off
Message posted on 04 May 2025 02:00 PM
Sky Q box turns off
Sky box seems to crash randomly and has to be switched off and on to restart.
Message posted on 04 May 2025 02:17 PM
Re: Sky Q box turns off
Hi @Smiffy201
