05 Feb 2025 09:33 AM
My sky box keeps switching off by its own accord , upto 20 times a day , wether watching live tv or catch-up and apps . No warnings whatsoever , screen goes blank , switch off and on again , Not on eco mode , as all these settings are off , well ventilated , on its own in the tv unit . All software upto date . Any ideas anyone
05 Feb 2025 10:19 AM
