Discussion topic: Sky Q box regularly not showing correct tv program
This message was authored by: Jaybetec
Sky Q box regularly not showing correct tv program.  Titles not shown on various channels.  Then not able to pause or rewind current viewing channel
This happens at least once a week.  Disconnected all leads and power fixes it for a short time.
Is my box need replacing or is there another solution?
Re: Sky Q box regularly not showing correct tv program
Hi @Jaybetec
