Discussion topic: My sky remote wont connect to tv anymore
This message was authored by: Sambrown1402
My sky remote won't connect to tv. Neither are new and have always worked.  The remotes batteries are fine
Re: My sky remote wont connect to tv anymore
Hi @Sambrown1402
First try rebooting your Q box?
Once the box is back up and running,
