Discussion topic: Sky Q box problem joining network
Message posted on 11 Jun 2026 12:29 PM
Every time I switch on this sky q box there is a problem joining the network. It usually eventually connects but not today. There is also the error code MR102 at the bottom of the screen.
Message posted on 11 Jun 2026 12:42 PM
Re: Sky Q box problem joining network
Assume this a mini box @Taylor444
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 11 Jun 2026 01:13 PM
Thank you for your reply. I am currently going through the process you advised. Oh BINGO! It's now working 😅. Fingers crossed I don't have to do this every time I switch this tv on. Many thanks for your assistance.
