Discussion topic: Sky Q box overheating
This message was authored by: Jjenkins
Sky Q box has started freezing and is overheating
Re: Sky Q box overheating
@Jjenkins SKYQ boxes do tend to feel warm as the case is designed to dissipate heat from the inside out.
However the boxes need to be in a reasonably ventilated location and not inside a closed cabinet.
If the box is getting too hot that it stops working, try rebooting the SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot, if that doesn't work call SKY and talk to an advisor about a possible replacement?
This message was authored by: PeteRG41
It might also be getting dusty inside the box.
Remove the power cord and the other cables, then give it a good blow through all of the ventilation ports.  That might shake a few of the cobwebs out.
____
Pete.
