Discussion topic: Sky Q box or remote not working
This message was authored by: Balbi+Balu
My Sky Q box or my remote is not working?
Re: Sky Q box or remote not working
@Balbi+Balu
You will have to provide more information in order for us the advise you.
Hi @Balbi+Balu
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
This message was authored by: ksaro1
Also, make sure the batteries aren't dead in the remote.
