Discussion topic: Sky Q box and mini controller problem
This message was authored by: Controller+issue
Hi
Does anyone know how to program a mini box controller to work separately from the Q box one as when I try and pair it with the mini box it picks up the Q box through Bluetooth and pairs that rather than the mini!
thank you
This message was authored by: profile
Re: Sky Q box and mini controller problem
How close together are your Q box and mini box?
The obvious thing to try is to take the minibox further away before trying to pair it. Or move the remote as far away from the Q box as possible before trying.
Avatar for Controller+issue
Hi, it's only a small house so the Bluetooth gets it from upstairs too.
@Controller+issue
So how about (temporarily) wrapping the Q box in aluminium foil to mask the  bluetooth signal while you pair the minibox. (Don't do it for any length of time though  - the Q box will overheat!)
Hi, I was on the phone to sky last night with no answer for 30 mins and then they shut at 9.
I'll try that idea and see if that works tonight.
