Discussion topic: Sky Q box not working
Message posted on 13 Feb 2025 07:36 PM
My sky Q box works for about an hour then it starts making a buzzing noise and does not work
Message posted on 13 Feb 2025 07:51 PM
Re: Sky Q box not working
Hi @Lola27
