Discussion topic: Sky Q box not working
Message posted on 15 May 2024 07:53 PM
Hi I live in Preston and my sky is not working it just keep saying my sky Ariel is not getting any signal has anybody else getting this problem.
Message posted on 15 May 2024 07:58 PM
Re: Sky Q box not working
Where you live won't be relevant. If a message is displaying ”No signal” it tends to be from your TV not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Message posted on 15 May 2024 08:00 PM
Hi @tather That sounds like a problem with your TV and not Sky Q. Normal terrestrial TV has an aerial and Sky Q has a satellite dish. You also mention that you are not getting a signal. This could mean that your TV is not on the correct HDMI port for Sky Q.
