Discussion topic: Sky Q box not working
This message was authored by: mkderby
Experienced problems since last night. Been fine for a year. Changes batteries in the remote. Reset that. Powered of the box. Reset box, nothing. Unplugged and followed all the tips, just an amber light on display.
Re: Sky Q box not working
Hi @mkderby
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote again.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
