Discussion topic: Sky Q box not working
This message was authored by: Qaideazam
Yesterday my sky Q tv box was having satellite signal issues. Ive left it until today but the tv isn't turning on using the controller, and when I turn it on via the button on the tv box it just keeps playing the ad for sky Q tv box over and over.
Re: Sky Q box not working
Hi @Qaideazam
If the button on the box has turned the Q box on then with the Q box on with green LED:-
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
