Discussion topic: Sky Q box not working
This message was authored by: EmmaBaugh
Sky Q box stopped working yesterday. No power going to it. I'm trying to order a replacement but your system is saying technical issues.
Re: Sky Q box not working
@EmmaBaugh Maybe try ringing Sky then?
Hi @EmmaBaugh
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
