Discussion topic: Sky Q box not working with Mini Box or Sky GO
This message was authored by: Gary+McRae
So for the last few days both my mini boxes wont display any channels or recordings from my main sky Q box.  I can only use apps through both mini boxes.  Sky GO on my phone and PC also can't see the sky Q box.  Sky Q main box working fine otherwise, shows ticks for all services, internet etc.  My main Q box for the last year has needed regularly turning off and on again because of freezing, but this is normal it appears with sky's rubbish equipment.
So far i've tried
1. Unplugging sky Q box several times
2. Unplugging both mini boxes several times
3. Unplugging my router (not sky)
4. Reactivating both Sky Q and Sky Mini boxes in settings menu of main box
I'm about at the point i'm ready to cancel Sky completely, the equipment is unrealiable (both main box and mini boxes regularly need resetting) and the prices are out of control.  If it doesn't record the F1 this weekend because of freezing, the whole lot can go in the bin and sky can come get it.
Should I just book an engineer visit and tell him to bring a new box?
Re: Sky Q box not working with Mini Box or Sky GO
So far i've tried
Hi @Gary+McRae .
Try a Reset Settings in the main Q box hidden menu.
Once the main Q box back on reboot it again and then when the main boxt  is completely back up and running reboot the minis.
Reboot the minis as above.
. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or previously connected mini).
Avatar for Gary+McRae
Tried Resetting as above, no change.  The mini boxes do say they are connected to the Q box, but u can't access recordings or watch any channels.  I'm thinking its time to book an engineer to come out with a new Q box.
