Discussion topic: Sky Q refusing to connect to broadband
Message posted on 13 Sep 2024 07:32 PM
Hi, my Sky Q box and Sky Q mini are both refusing to connect to my sky broadband. I have disconnected and reconnected my phone and other devices and they have reconnected no problem. The sky boxes however are just stating "unsuccessful connection" if I try the WPS approach, or state "password incorrect" if I try to manually connect to the broadband. I have reset the router. Reset network settings. And done a full setting reset on my sky q box and the issue still persists.
Message posted on 13 Sep 2024 08:31 PM - last edited: 13 Sep 2024 08:32 PM
Re: Sky Q refusing to connect to broadband
Do you know if you have the Sky Max router?
If you have, you need to use the router SSID and password in a main Q box Network Reset.
With other Sky routers you need to use WPS on the router when carrying out a Main Q box Network reset.
ie see below
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
See WPS button location.
Message posted on 13 Sep 2024 09:27 PM
I'm have a standard sky broadband. Can confirm I was pressing the WPS button until it flashed as per sky instructions. I also attempted manually adding the sky broadband to check whether this way may work and both failed stating that it was unsuccessful.
Message posted on 13 Sep 2024 09:37 PM - last edited: 13 Sep 2024 09:39 PM
.Q will only connect to standard Sky router by WPS
......... was pressing the WPS button until it flashed as per sky instructions........
Edit.
What colour was the WPS light flashing?
Assume the Main Q box WPS was flashing and you pressed the router WPS within 2 minutes?
Message posted on 13 Sep 2024 09:42 PM
I tried both as per sky guidance.
WPS button was flashing orange and I can confirm I pressed it within 2 minutes, all 4 times I tried to connect it that way.
Message posted on 13 Sep 2024 09:45 PM
How far is your Main Q box from the router @Nataliesmxth ?
Message posted on 13 Sep 2024 09:58 PM
It's literally next door, we live in a bungalow so nothing of great distance. Maybe 15ft at most? It has been connected to the broadband before
Message posted on 13 Sep 2024 10:04 PM
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works. Not sure if they will resond over the weekend.
In the meantime if you haven't already
Try a Reset Settings in the Q box hidden menu. I don't know if you've done this or just a reboot.
Message posted on 13 Sep 2024 10:05 PM
Hi, many thanks for your escalation.
Have already tried the settings reset too and was to no avail. Will await skys email/message. Thanks again 🙂
Message posted on 14 Sep 2024 08:21 AM
Sky's guidance says to try the SSID/password approach for a Sky router? That's odd, that never works afaik.
Message posted on 14 Sep 2024 09:11 AM
The advice came from a customer service agent who told me they booked an engineer that also never got booked so I mean pinch of salt and all that. However, thought it was worth mentioning in case it was suggested again...
Message posted on 14 Sep 2024 09:37 AM
Thanks for escalating this. We’ve sent an invite to @Nataliesmxth to chat.
Message posted on 14 Sep 2024 10:20 AM
On the back of the Sky Router press and hold the small reset button for a few seconds and the router will reboot (this is not the same as powering it off and on) when all the lights have come back on at the front you should be able to reconnect your main Q box to the network.
Message posted on 14 Sep 2024 10:22 AM
Done and didn't work unfortunately. Have reset both the sky q box and the router and both are still not playing ball.
Message posted on 14 Sep 2024 10:23 AM
Did you reset the router rather than switching it on and off?
