Discussion topic: Sky Q box not responding
This message was authored by: Beth83
Received a sky q box but it isn't responding. Tried changing the batteries in the remote and still nothing. It's stuck on the "accessibility in Sky q" screen
Re: Sky Q box not responding
@Beth83
Sky have suggested the following...
  • Unpair their Sky Q remote from the box by holding 4&6
  • Wait for the remote to flash
  • Then dismiss the information screen "Skip & set up later"
  • Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
This message was authored by: Gemma1476
Thanks it worked like a treat
