Discussion topic: Sky Q box not connecting
Message posted on 17 Nov 2023 04:07 PM
My sky Q box will not connect to the tv when you press the standby button to turn sky Q box on it shows a green light but there is no connectivity to the tv I have checked all wires and connections they all seem fine it's been like this for 2/3 days now
Message posted on 17 Nov 2023 04:31 PM
Re: Sky Q box not connecting
@Yas91 when the green light is on try pressing the following buttons on your remote home 1080 home
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 17 Nov 2023 06:40 PM
This home1080home just changed my screen resolution, nothing to do with connectivity how do I change it back please??
Message posted on 17 Nov 2023 09:23 PM
@Gemst the home1080home rssets the box to 1080 i the default setting for your box you can change this back to what you need through settings audio visual
Message posted on 17 Nov 2023 09:59 PM
