Discussion topic: Sky Q box not connecting to Sky WiFi
Message posted on 08 Aug 2024 02:54 PM
Tried all the helps
resetting sky q, resetting router, switching everything off, WPS button, manual connections. Nothing working.
amazon stick is, as is WiFi throughout the house.
anything I'm missing?
Message posted on 08 Aug 2024 03:09 PM
Re: Sky Q box not connecting to Sky WiFi
@Peacoc wrote:
Tried all the helps
Hi @Peacoc
Exactly what happens during the following procedure?
Message posted on 08 Aug 2024 03:49 PM
Did all this in that order but is just searching for connection when I reconnect and saying "Unsuccessful connection, please try again"
Message posted on 08 Aug 2024 04:37 PM
Message posted on 10 Aug 2024 10:57 AM
I am having the same problem.
have tried all the above steps and still my sky a box is not connecting to my sky broadband router. Have unplugged and reset everything and gone through set up process again tried via WPS button on the router and manually but nothing works. How can I speak to someone to resolve??
