Discussion topic: Sky Q box needs disconnected
Message posted on 23 Apr 2025 08:05 PM
Hi, recently my Sky Q box has been stuck in stand by, now on a daily basis I need to disconnect from the mains before it will work. This is also causing an issue with my mini box in another room. Recordings also keep failing as it's says there has been a power cut when thi isn't the case.
before the mini box will work both it and the main box need to be disconnected.
please advise how this issue can be resolved.
Message posted on 23 Apr 2025 08:11 PM
Re: Sky Q box needs disconnected
Hi @Craigie+D
Try a Reset Settings in the main Q box hidden menu.
