5
This discussion topic has been answered Discussion topic: Sky Q box lost connection
This message was authored by: Jend2
Our Sky Q box lost connection today at 12:03.  I have tried absolutely everything I can find on sky info.  Reset both Sky Q box and router multiple times and still showing the same messages.
Network connection - X
when we try to connect we just get no where
The internet is working in all other devices in the house.
Please help 🙂
Re: Sky Q box lost connection
Hi @Jend2
As you are aware,  on Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
@Jend2 what Sky router do you have is it the black one or the newer white one ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Jend2
It is the black one
@Jend2 wrote:
It is the black one
@Jend2 so when it says in the third picture to press the wps button on your routeer what happens (the WPS button is on the right hand side of the router on the thin edge)
Hi @Jend2
Avatar for Jend2
Oh my goodness, I feel so silly.  I have looked all day and didn't see that button! We have been pressing the one on the Sky Q box.  Thank you ☺️
