Discussion topic: Sky Q box keeps temporarily freezing
This message was authored by: linzotash
Sky Q box keeps temporarily freezing, tried rebooting not solved the problem
Re: Sky Q box keeps temporarily freezing
@linzotash You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
