Discussion topic: Sky Q box keeps freezing
Message posted on 14 Mar 2024 07:13 PM
My Sky Q box keeps freezing and not respinding to either the remote or the buttons on the box. Sometimes this is in standby and it wont turn on, sometimes when I am watching or recording. I have to unplug and reboot every time. 3 times already this evening!
Software appears up to date when I go to settings.
Any ideas what I need to do or do I order a new box?
Message posted on 14 Mar 2024 08:03 PM
Re: Sky Q box keeps freezing
Hi @PaulE100
Message posted on 14 Mar 2024 08:50 PM
Thanks for the suggestion. I'll give it a go, although probably tomorrow now.
