Discussion topic: Sky Q box keeps dropping network connection
Message posted on 11 Jan 2025 04:55 PM
I recently upgraded to sky Max Hub but ever since then my Sky Q box keeps lossing network connection which means the mini boxes aren't working either. When I check online on My Sky they say everything is working. Can someone tell me if this is normal for the 1st few days or have I an issue with my Sky Q box?
Message posted on 11 Jan 2025 07:08 PM
Re: Sky Q box keeps dropping network connection
Hi @Marcy87
If you have the latest Sky Max router then you need to connect it to to your Q box as if it is a 3rd party router.
This means you need to connect it to your Q box as follows.
First reset your broadband router by holding the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
As the max router is like 3rd party broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 12 Jan 2025 10:06 AM
There is no reset button on the back? The only button on the router is the wps.
Message posted on 12 Jan 2025 11:55 AM
@Marcy87 what router do you have the black or white router ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 12 Jan 2025 04:28 PM
White box
Message posted on 12 Jan 2025 05:35 PM
@Marcy87 wrote:
White box
@Marcy87 on the white sky max hub removing the power will cause the hub to reboot but to do a factory reset on the white hub you press and hold in the WPS button on the side until the led flashes and then release it which takes at least 10 seconds.
This page explains what the various colours of the light your hub mean https://www.sky.com/help/articles/hub-lights-explained-max-hub
Message posted on 12 Jan 2025 06:43 PM
I've tried turning the router off and on, I've tried holding the wps button and the sky a box does connect to the internet for about 1min and then it goes again. The sky q box is working for to watch TV but keeps saying no internet connection so can't use any apps or any mini box in the house.
Message posted on 12 Jan 2025 09:33 PM - last edited: 12 Jan 2025 09:34 PM
Hi @Marcy87
As I posted earlier you need to connect a Sky Max router to your Q box like a 3rd Party router.
ie
Carry out a Network Reset found in Q box Home - Settings - Setup - Network.
Message posted on 12 Jan 2025 11:02 PM
Tried that and it does connect but for about 1min and then comes back up with an x beside network connection.
Message posted on 13 Jan 2025 07:19 AM - last edited: 13 Jan 2025 07:44 AM
Welcome to the way Q has behaved with 3rd party routers since forever.
Maybe Sky will give you a Q booster which you can wire into the router and that acts like its an old school Sky router itself.
Message posted on 18 Jan 2025 04:06 PM
Thanks for all your help folks. I had to phone sky and they sent out an engineer and he had to fit a booster. He said it was very common now with the new routers, the Sky Q boxes aren't connecting to them anymore without a booster or by running an Ethernet cable which is rubbish. Then I had an issue with the mini box connecting and they had to send a new replacement out. Complete disaster but sorted now so far, fingers crossed.
Message posted on 18 Jan 2025 05:51 PM - last edited: 18 Jan 2025 05:51 PM
Welcome to how badly it had always worked for the rest of us not on Sky bb 😁
edit; haha realised I already said this
