Discussion topic: Sky Q box keeps disconnecting
Message posted on 04 Dec 2025 01:43 PM
Randomly have to keep restarting Q box and mini box
Message posted on 04 Dec 2025 03:58 PM
Re: Sky Q box keeps disconnecting
Hi @Bob192
If they are disconnecting from your Broadband and the Internet,
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band..
