Discussion topic: Sky Q box keeps disconnecting from the internet
This message was authored by: Jorgybear
Every time I turn my Sky Q box on from standby, I have to re-connect to my broadband router. Every other device in the house is fine
Re: Sky Q box keeps disconnecting from the internet
Hi @Jorgybear
Have you exactly completed the following?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Avatar for Jorgybear
My broadband isn't with Sky, I should probably have said that in my original post.
as all other devices in the house work, I don't see how resetting the router would help (I reckon the problem has to be with the Sky box), but I'll try it.
This message was authored by: kizzyskye
Mine is doing the same, I have to connect Q box to WiFi every day for past few days. I'm with Vodafone broadband.
every day I reset and connect. Getting fed up with it now
This message was authored by: Noot-88
Mine does the same too, sometimes disconnecting twice in a day. Not with sky broadband either. It's very frustrating considering getting rid of sky.
One thing worth trying is separating your 2.4 and 5 GHz wifi bands into different SSIDs and specifically connecting the Q to the 2.4
you need to do this on the router admin page.
Thank you I'll give that a go
This message was authored by: Bigj17
Have tried everything suggested here but only thing that works for me is to switch off at the mains for a while and then switch back on. It always picks up wi fi after that obviously if you reset it in network settings it will work but when you have  long complicated password it's a pain in the neck.
This message was authored by: Me134
Have you turned off eco mode on the Q box to make sure it's not that that's disconnecting from the WiFi at night?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
2 Windows desktop PC's hardwired to each Deco, everything else using the Deco WiFi
Have just changed setting so will see if that works didn't know about echo setting thanks for information
This message was authored by: CCox38
  • Turning standby mode from eco to active seems to have worked for me 🙂
